May 12, 2022 at 12:26 pm
Hi
You can access the temperature of solid and fluid zone using the macro "C_T(c,t)" which will give you the cell temperature at cellÔÇÖs IDcand thread pointert
For post-processing part, you can directly select the zone/ surface of corresponding cell zone to get data. It is done as usual as taking any data in Fluent. For solid, instead of the regular cell surface, we select the surface from the newly created zone.
