Forum Moderator
Reference temperature (in the Reference Values) shouldn't alter convergence. Since you have a heat flux and a bulk volume temperature I'd calculate manually, that way you can compare with your experiments: HTC is a comparison value, what you're really after is a heat flux as that's what you will measure in reality.
