Romariode
Yes, Water enters and evolves biogas. Liquid Water is used to simulate the flow field here since biogas slurry is a low concentration solution at the initial stages of biogas fermentation and also it has flow liquidity that is similar to that of water. In this test, the slurry is assumed to obey the continuity and momentum conservation equations.
Air is present in the dome initially.
