Navya C
What kind of error analysis are you referring to. Can you explain this in detail to understand the requirement correctly?
Do you want to compare the results against the theoretical error analysis you performed?
If you are looking for the error difference after each simulation step. you can Right-click on the Results and check solution data and Profile on the popup window, as shown below.
Regards Navya
