Surya Deb
Can you compare the body temperature profiles side by side to make sure you are importing the right values?
Also, you can test with a simple model by applying a temperature boundary condition on the surface.
Change the temperature boundary values from low to high and then see the relative changes in the overall stress.
Regards SD
