Chandra Sekaran
If you did not do 'Clear all generated data' then possibly the results file is still available and you can try to reload it.
Go to 'Solution' --> right mouse click--> open solver files directory. Check if there is a results file (file.rst if structural, file.rth if thermal)
Click on Solution, Open the solution tab--> read results file as shown below. Read the file.rst.
