k1124473
Hello RK, Thank you for the reply. I will do my best to show you my steps. I've opened Ansys Forte 2021 R1 Launcher. Selected Simulate (FS). Once Forte opened up, I went to Help>Tutorials>5. Port-Injected Spark Ignition Engine> 5.1.1. Files Used in This Tutorial and downloaded the files. The reason why I did not go through the tutorial is because I understood the .ftsim file was completed tutorial and its ready for simulation.
I am aware that this is where I might have gone wrong. For my university project I am comparing Ansys results with MATLAB. And, I wanted to see what results Ansys produces. I did aim to save time. But, it would have been quicker by now to go through the whole tutorial. As I write this, I am 70% through the tutorial and will let you know what I get. So, back to the steps. Back in Forte, I’ve Opened the SIEngine_PortInjected_AMG_Tutorial.ftsim file. And, selected Yes for Project Preservation.
Afterwards, I’ve Generated Mesh to see what it would look like and went on Run Simulation.   Under Run Simulation I pressed the Green Play button to start the simulation and received the following message, below.
After that I went to Run Settings and deselected Check Valve Seating Before Starting Run.
After that, I went back to Run Simulation and pressed the Green Play button again. This action made me think that the simulation has started and everything is okay. But, after all night of running simulation I received no results.
That’s when I opened Forte Monitoring. Selected Nominal under Select Runs to Display and found out that the simulation was “Killed”.
Are you able to help?   Where did I go wrong?   Thank you. Kind Regards, Arturas
