Modal is a linear analysis so nonlinear contact is not permitted in the analysis. When nonlinear contact is in a model and works in a Static Structural analysis, Mechanical will automatically convert nonlinear contact to bonded contact if the initial contact status is closed, or it will ignore the nonlinear contact if the initial contact status is not closed, when a Modal analysis is requested.
