DrAmine
I can only confirm that the TUI command is correct. I cannot judge the other aspects affecting Tecplot itself. You might try another kind of export to check if it you have only issues with the Tecplot export (example using ASCII). Can you try on another case if you reproduce the issue (like a dummy pipe flow)?
