Since you have an axial load, if you use a displacement input instead of a force input, the need for stabilization will be greatly reduced. Insert a Probe to request the Reaction Force for the Displacement BC to plot the load curve vs displacement. If you need stabilization, it is likely to only be needed after the maximum force has been reached.
