marius1.gratzl
My flow is turbulent with Re>30.000
My inlet BC is set to Massflow inlet, with the massflow rate you can see in the image above. And yes, think of it as a pump pumping fluid in and out of the domain. Negative massflow = sucking fluid out and positive massflow = pumping fluid in
