As you've (probably) not shared the topology (SpaceClaim) or created a multibody part (DesignModeler) the various volumes aren't connected. That then gives you the interface zones. Fix that, and label the cell zones (fluid & solid) and you may find you have fewer wall zones.
Note, you will always get a different surface label with each volume label: that's intended.
