Thomas Magnac
>>Sorry, images not going through..<<
I would recommend using a 3D irradiance sensor instead of a 2D irradiance sensor, for the following reasons:
  1. 2D irradiance is only placed on a virtual plane, there is no mesh on this plane.
  1. On your solar collector, you probably need absorption on it but a 2D irradiance sensor has no optical property to get this information.
Here’s a suggested workflow to perform a SPEOS – Mechanical connection:
In speos:
  1. Named Selection group is the key element to correctly perform a Multiphysics simulation between Speos and Mechanical.
    • Make sure you have created an NS for each component you want to analyze.
  • Make also sure these groups are applied to each geometry (assign your material with Groups, not bodies)
  1. XM3 data export:
In Workbench:
  • Geometry imports from Speos to Mechanical -> Use External Data block to import data exported from XM3 -> Thermal block allows to manage thermal simulation in Mechanical
Then you can perform a thermal simulation (in this example is a steady-state thermal simulation but it depends on your project)
