Erm....  The boundary condition value is there to give the solver a number when material enters the domain. The turbulence values (k, e, w, etc) are then calculated based on the geometry, flow field etc.  As you don't have a boundary value you're starting the model off from initial conditions: setting k, e (or w) as 0.01 isn't unreasonable.
