Yu Bi
Hi, you can use connection stiffness (structural stiffness) matrix (right-click on Connection > Insert Connection > Connection Stiffness). However, you need to use a pre-solve script (if you work in Aqwa Workbench) to remove the NASF option in the *.dat file to enable the program to use the connection stiffness.
