The base software should work for 4 cores, beyond that you will need HPC licences. For 24 cores you'd need two packs (which would give you up to 36 cores). However, parallel meshing speed up only really works if you have multiple disconnected parts, so you may, or may not see much improvement with parallel meshing.
