Poor quality elements means the mesh is degenerate, so can't be completed. However, incorrect input could mean you've read a surface into a 3d mesh or the like. Screen shots of the geometry in Meshing and the settings will help.
If it's a rectangle, did you set geometry (and hence the whole workflow) as 2d?
