July 6, 2022 at 12:28 pm
Hi @amando.gallardo,
Setting the analysis type to 2D from the properties might be helpful.
You can also use the Project command to project the features on surfaces or solids.
Assigning a cross-section to a line body in SpaceClaim itself makes it easy for the user to visualize in mechanical.
The following video may be helpful for the same- Creating and Analysing a Beam and Shell Bridge Model with ANSYS SpaceClaim and Mechanical - YouTube
You can also get more details on Body Filtering property and Mixed import resolution from the following references-
General Information (ansys.com)
Mixed Import Resolution (ansys.com)
Solutions to some of the errors can also be found in Problem Situations (ansys.com).
Hope that helps!
Thanks,
Sahil
