This is a bug. Wildcard for destination filename doesn't make sense. This has been corrected in revision 111551 (LS-OPT 2022R1). In this version, you can define d3plot* as source filename and simply define "." as destination to copy all d3plot files to lower stage run directories.
If you don't have access to new version, please use "run jobs in directory of stage" checkbox in LSPP stage so that LSPP solver jobs are executed directly in LS-DYNA stage. This will not require any file transfer operations.
