jonl
Hi! Your remote displacement will turn and move the wheel, while the rotational velocity doesn’t actually move anything. It creates forces radially outwards (centrifugal force) as if your part was spinning. Whether you chose the surfaces correctly depends on the problem you are investigating, but your selection will at least make the wheel move and turn.
Edit: Thought this was static structural, don't know if this applies to transient
