Hi @shao ping,
After you plot the voltage waveform. Right mouse click on the plot and select trace characteristic>All
On the pop-up window, choose the function rms and specify the range then Add trace characteristic.
Then you should see the Rms voltage of the Voltage waveform on the plot.
Regards
Navya
