A Response Spectrum Analysis (RSA) does not calculate the response at a particular frequency. It calculates the peak response over the frequency range. When you enter the command /INPUT,,mcom; you read the file.mcom file that contains load case commands that combine the modal resultls. You should do a harmonic analysis (probably a mode-supe harmonic) to calculate the response vs frequency.
