DrAmine
Okay: first start simple and use a plain SST turbulence model (without any additional sub-models). Use a constant surface tension and try again. You need to find out the reason for this behavior: it actually starts diverging at the beginning of the time step.
Can you  describe bit more the problem you are trying to model?
