With thickness turned on, you can see the effect of the offest to Top or Bottom of the shell elements.
All the surfaces are on the same plane.
The thin part surface was imprinted with the thick part outline to make a clean edge for the contact.
ANSYS2022R1 archive: https://jmp.sh/FHR1SvH
