July 5, 2022 at 1:27 pm
You can do a copy/paste of your designs from the Parameter Set to the Correlation.
To do it, you need to set the Sample type of your Correlation as Custom, then you can use same existing mechanisms for DOE:
- select designs in the Designs table of Parameter Set, copy them, and paste them in the Designs Points table of Correlation
- select designs in the Designs table of Parameter Set, RMB click > Copy Design Points to > selecte your Correlation component
- or from the Correlation component, select the Parameters Correlation node in the Outline, RMB click > Copy all Design Points from the Parameter Set
