Ram Gopisetti
Hi, you can set the units for the model to be exported in the analysis settings of the LSDYNA and for the measurement of distance you can check ELE tools>> measure>> and use DIST N2N and selected two nodes , this also works for postprocessing to track the dimension changes over the simulation.
Cheers, Ram
