aschide
Hi Robert, thank you for your suggestion. I've set up my Fluent case with the monitors you described. When I run the Fluent case by itself without Rocky coupling, the .out report files are created. However, when I couple the same Fluent case file to Rocky, the report files are not created. Do you have any suggestions about how I could fix this? I tried a few different Fluent and Rocky case files and they've all had the same issue.
