kuuku.botchway
Hi, Thanks for the reply.  Soo I've attempted to run the simulation with a constant surface tension previously and received the same error.  I recently just attempted the k-epsilon model without any additional options (no enhanced wall treamtmant and thermal effect) and a constance surface tension now the issue seems to have gone away, but I'm not getting the results I needed.  I'm currently testing if the material I'm using is causing the issue
