Images of the results will help. Along with convergence plots. I also suggest replying to answers when they're given: opening a second thread tends to annoy us more than it helps you get an answer.
In terms of the models. I'd expect near enough the same result for SST and k-e if you use the enhanced wall treatment and converge both. This assumes the mesh is adequate.
