nguyenminhhieu15122000
Thank you so much for your help.
I already have the force, pressure, and velocity parameters so I think I do not need to measure the Force.
I am wanting to split the problem step by step.
Step 1 then I want to find that displacement.
Step 2 then I want to get the result of strain energy so that through the Eq, I can calculate the Heat rate
Step 3, I will provide heat rate and convection conditions to do it on Steady-state thermal model.
