DrAmine
Okay. Now do the following: In Fluent allow recording Journal File. Now copy paste every line into Fluent and exectue them. Stop recording. Check the journal file: is it similar to the lines you are using?  If you then use the newly created journal file: will it work? If not I will have a look.
