Dubey92
Rob, thanks for your suggestion. I am using a very small courant number for VoF(0.05). I am applying the Laser source on on the top interfacial cells between the gas and the metal. The temperature values are in the range what I expect. The issue is only with the convergence of continuity equation. I haven't checked the velocity values yet but will do.
