Aniket
You can create an extension that has all the snippets that you have created using ACT. Make sure the ACT extension is loaded and simply pass the following via workbench journal (python based):
extension = ExtAPI.ExtensionManager.GetExtensionByName("").GetModule()
extension.functioninExtension()
When you are using Mechanical, You can automate APDL command snippets, but then again you will need to use the same two commands above, so why not change the things in GUI instead of changing them in command snippet?
-Aniket
