Have a look at the solidification/melting model in Fluent. Re the materials, you set ONE material for dry ice, and the extra properties are available to set once the model is switched on. This is a single phase approach. Otherwise you will need CO2-solid and CO2-gas as materials & some mass transfer: noting that the "solid" will be a fluid and need a multiphase model.
