1829116
Hi
Thanks for your reply
The simulation stopped at timestep 1061 and this is how the velocity and temperature looked like
This is how the velocity and the temperature looked at timestep 1060
At timestep 1040, the velocity and the temperature looked fine as you can see
I was not able to see the TUI since I closed FLUENT after the error showed. I loaded timestep 1060 and ran the simluation again and this is what I received:
In the original simulation, I received similar errors before it failed. Any idea?
