Increasing particle streams will reduce the parcel mass: that tends to give a more stable solution as the DPM source is more spread out.
Particles larger than the near wall cell may cause stability issues (hence more streams) and can mean the particle is closer to the wall than it's radius would permit. Otherwise, it'll work, but you need to be aware of the conflicts when analysing the results.
