sam
Hi Rob,
I have tried to play around with the Field Variable Register, however I don't see the difference on the mesh by changing the value. For example, if I want to excluded anything 5 inches away from the original boundary, how should I set it to?
Hi Amine,
Thank you for the response! which documentation are you refering to? Do they have any different fuction to replace the Normal Distance?
