1829116
Thanks Kaylan.
I will look into the solution you suggested.
Meanwhile, I have an additionalquestion. The first simulation I carried out included on the air part with walls BC kept as default. I received a SPL of around 140 dB. I carried a second simulation but imcluded the solid walls of my system. THe SPL dropped to 150 dB. Are these results accurate? Can ANSYS analyze sound reduction through solid walls?
Thanks
Hadi
