Ram Gopisetti
Hi Javat33849
1) can you be specific for ths question, the prepost will report you the min and max for the time on topleft corner.
2) you can use the section view from the bottom toolbar.
3) you can use the state option which will list you the timestamps along with the state numbers, upon selecting the entries of time you can see the graphics stage beeing updated with appropriate time stamp.
4) if i understand you correctly, there are no measurement points but you can use node based reporting using the DATABASE_HISTORY option.
cheers, Ram
