July 27, 2022 at 7:21 pm
This is a charge simulation, so please check if you have set the contacts properly. If you have added the contacts, please make sure the mesh order is correct if there is other material overlapped with the contacts.
Please also check that the material fills the simulation volume, as CHARGE does not like anywhere without a material property.
