brandon.hager.63
Thank you for your response. Just to clarify what you mean about transferring profiles, specifically for my application, I would first solve one case and then transfer the data from the exterior of that body to the interior of the other body in the other case? Each case would be solved individually and I would transfer any applicable data from the first case to the second. Am I understanding this correctly? Furthermore, can you point me towards a tutorial or document that details how to do this process.
Thanks again.
