July 29, 2022 at 10:24 am
Hi, serefbal
- You can set up the coils and windings under excitation and then create an external circuit using the same winding names used under the excitations.
- You can use a square wave generator or use a direct dc voltage depending on the duty cycle. if the two windings are excited separately you can use a separate voltage source for each.
- Since all the magnets are moving together you can define one band including all the magnets.
- The shape of the band/container object needs to be polyhedron. No need to worry about the mesh.
Navya
