Praneeth
Hi Steve,
Are you simulating the simulation model in cluster? If yes, then you need to install MPI. MPI is not required if you are running on a normal computer.
It looks like the errors on the screenshot are related to MPI. Please check if it is setup correctly.
All the very best,
Praneeth.
