srocca
Praneeth,
I have done simulations without the SMA using that port configuration you mentioned and it gives satisfying results. I wanted to take the model one step further by introducing the SMA connector. In the model I have the SMA touching the copper trace, but not sure if this is the best way to connect. Also, let me know if you think this path forward won't add much value to my results.
Thanks.
