Aniket
If you have a commercial license, can you please open a new Service request from the customer portal?
Also, in case you have a commercial license but don’t have TECS, which is required to open a new SR, A simple way of identifying which one is configured is to check if you can start Workbench directly from Inventor. If so, you are using the Associative geometry interface. If not, it is the most likely reader.
You can configure it using CAD configuration manager in the associative mode.
-Aniket
