August 2, 2022 at 10:27 am
Hi uhyor,
The rotor's initial position is set to such a position that the initial flux linkage of the phase-A winding is at its negative maximum value.
If you can not figure this out from your configuration.
The other way is - Run the model in open-circuit condition(set current =0). Plot the 3 phase flux linkage and induced voltage plotes.
The alignment angle or the initial position is reached when flux linkage is at maximum and induced voltage at the minimum.
In the below image firt plot is the flux linkage and the second plot is the induced voltage and the initial position is 7.5 deg.
You can right click on the plot and add x-market to mark the position.
Navya
