Generally, users simulate their models with lumped or waveports available in the tool instead of simulating with the connectors as this saves their simulation resources. The response with these ports will be similar to that of the Connector ones.
You can simulate with the SMA connector if required. Try to conncet the connector like in the experiment. You can also use the inbuilt SMA connector under 3D components.
All the very best,
Praneeth.
