DPM data is tracked on the particles, not on the cells (there are some exceptions when you are fully coupled). You may also find pneumatic conveyors to run at a higher volume fraction than DPM is intended for, and the diameter may also be a problem.
Not sure why you're trying to write out particle data, if you save a .dat.h5 or .dat.gz along with the case it'll post process fine in Fluent. Particle tracks and CFD Post can be a little messy.
