If you're switching between wall & wall:shadow that could explain the problems. Walls with cells on both sides use that naming convention, and on a solid-fluid bounary that means one side knows about the fluid data and the other doesn't.
Also, use Help from within Fluent. The link you provided is likely out of date and shouldn't be there.
