RM
To view coupled results in EnSight you might want to try following the mentioned procedure. (https://forum.ansys.com/uploads/149/HUBQN99F4L5X.pdf)
  1. Load System Coupling results. For the Look in field, navigate to System Coupling's results folder, \dp0\SC\SC\SyC\Results
  2. Load Mechanical results.
            > File > Open > Enable keep Currently Loaded data >  (load .rst file from \dp0\FFF\MECH) Enable advanced interface > Load all parts
    3. Load Fluent Results
           > File > Open > Enable keep Currently Loaded data > (load .rst file from \dp0\FFF\Fluent) Enable advanced interface > Select .cas file
            Edit both file names, replacing the step number with a wild card, as follows:
                    \dp0\FFF\Fluent\FFF.1-1-*.cas.h5
                    \dp0\FFF\Fluent\FFF.1-1-*.dat.h5           and load all parts.
Hope that helps!!
Rahul
